Activity Forums Event Videographers two cameras
  • two cameras
    Posted by Rick Dervisevic on December 4, 2005 at 9:47 am
    Next weekend I will be taping a wedding and it will be my first go with two cameras, I’ve borrowed my brother’s consumer mini DV Canon. My plan is to set his camera up on a tripod with my Rode directional mic and use my camera(VX2000)for close ups and effect shots. I edit with Sony Vegas 6.
    Any tips or things I should prepare in advance? Is there a way to sync the cameras or is that even important?
    Mark Suszko replied 20 years, 8 months ago 3 Members · 2 Replies
  • Velma
    December 4, 2005 at 12:19 pm
    Just make sure the stationary camera (since it will be your main cam) is in a place where no one will block it.
    You sync the cameras up in post. It’s really very easy. But this is the key to an easy sync: Keep both cameras rolling continuously. Do NOT hit the stop button on either camera during the ceremony for any reason. The only exception would be a tape change if the ceremony is long.
    In post, I usually use an audio cue to sync them. Just before the beginning, there’s always a loud cough or child noise or something. Or I sync them on the first note of a certain song. Other people use different methods.
    I also make sure they are both white balanced the same. Makes for easier color correction in post.
    good luck,
    velma
  • Mark Suszko
    December 5, 2005 at 5:41 pm
    Flashbulb pop done in view of both works well too. And looking at a blow-up of the audio waveform makes it easy to slip and slide until they match.
