Activity Forums Adobe Premiere Pro Two cameras, wildly different timecodes. Can I simply offset one?
  • Two cameras, wildly different timecodes. Can I simply offset one?
    Posted by David Friedman on December 21, 2015 at 8:01 pm
    I shot an event with two cameras (c300 and c300mkII). The timecodes are wildly out of sync. I don’t need them to be perfectly synced, but I’d like to be able to view all my clips from both cameras in the same bin in roughly chronological order.
    I know the timecode on one camera is accurate. Is there a way to offset the timecode on all the other camera’s clips at once so I can make them similar?
    (Assume that both cameras were using Time Of Day timecode, and one just had the wrong time set).
    I feel like this should be simple, but I can’t find a clear answer.
    David
    David Friedman replied 10 years, 9 months ago 2 Members · 4 Replies
  • Vince Becquiot
    December 21, 2015 at 8:51 pm
    Hi David,
    Try right clicking on the clip Modify > Timecode. You can match to a current frame of change the starting timecode value.
    Vince Becquiot
    Indigo Live | Kaptis Media
    San Francisco Bay Area
  • David Friedman
    December 21, 2015 at 9:01 pm
    I tried that, but maybe I’m missing something. If I select all the clips from camera B and change the starting time code value to a specific time, it makes that the Media Start value for all the clips from that camera. That’s not what I want. I just want to say “For all these clips, offset the start time by X amount”.
    Am I misunderstanding how to do that?
  • Vince Becquiot
    December 21, 2015 at 9:13 pm
    Got it, I thought you had a continuous recording. Then you might try to synchronize via audio. Once your clips are in the timeline, select both clips > Synchronize and choose audio. Makes sense?
    Vince Becquiot
  • David Friedman
    December 21, 2015 at 10:04 pm
    There are dozens of clips. And I don’t have audio to sync them from, unfortunately. It’s not about syncing for a multi-cam setup, just for my own organization going through the footage. It would be nice to have the clips from both cameras all together in roughly chronological order.
    I’m kicking myself for not checking the clocks before the shoot.
    David
