Activity Forums Avid Media Composer Two Avids, One Drive
  • Two Avids, One Drive
    Posted by Andrew Thompson on July 31, 2012 at 9:46 pm
    Is it possible to store MXF files on one Mac Pro (running Media Composer 5.5) and allow a second system to access the same material via direct ethernet connection? Essentially I want to use one of our avids as a makeshift unity.
    Richard Sanchez replied 13 years, 9 months ago 2 Members · 1 Reply
  • Richard Sanchez
    August 1, 2012 at 12:38 am
    If you’re using OSX’s built in File Sharing feature, the Avid might not see the drive unless you use the “alldrives” console command. If the media is on system 1, and system 2 is connect via ethernet, I wouldn’t allow system 2 to render, import, or capture to system 1. That is because the Avid, by default is going to want to write files to the AvidMediaFiles>MXF>1 directory, but if you have two system trying to simultaneously write media to that folder, it will most likely cause problems. The Unity software changes this, where the Avid will create a folder based upon the computer name and then numerical numbers. So Instead of AvidMediaFiles>MXF>1 It would be AvidMediaFiles>MXF>Edit01.1
    Just be careful about your media creation settings.
    Richard Sanchez
    Los Angeles, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
