Activity › Forums › Apple Final Cut Pro Legacy › Two active viewers
  • Two active viewers
    Posted by Kevin on June 8, 2006 at 9:53 pm
    Hi list,
    Having two viewer windows open I can only paste (P) from the main window, not the second one.
    Is there anyway to hotstroke this ability so I can copy into the time line from either window with just noe stroke.
    Many thanks and warm regards,
    Kevin
    Martin Baker replied 20 years, 3 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    June 9, 2006 at 3:08 am
    The active viewer is the source if an edit’s made from it to the sequence. There’s not a keyboard shortcut assigned to select any “new viewer” past the Viewer window, (note the word “Viewer” in it’s lable) Cmd+1 activates the Viewer window. But you can go back to the Browser by keyboard command, then by keyboard select the clip and hit the return key and it’s New Viewer becomes the active source window so that’s the keyboard shortcut to it.
    Jerry
  • Martin Baker
    June 9, 2006 at 11:01 am
    When you say “paste” I’m guessing you probably mean the insert/overwrite etc keyboard commands which will only work for the main Viewer and not any additional “new viewers”. If you want to work with multiple source viewers then you can put the clip in the sequence by dragging it to the Canvas or Timeline window, or alternatively through regular copying and pasting.
    Martin
    Digital Heaven, London UK
    Unique plug-ins and tools for Apple Pro Apps
    NEW! BigTIme – resizable timecode display for FCP
