Activity Forums Apple Final Cut Pro Two 48khz sources with audio drift
  • Two 48khz sources with audio drift
    Posted by Jim Rage on October 23, 2018 at 9:25 pm
    Video of issue: https://www.youtube.com/watch?v=X0Ttt-aPKkw&feature=youtu.be
    I’m having trouble syncing my audio and video. I recorded on multiple cameras and a zoom audio recorder. Everything was set to 48khz, but the audio still drifted out fairly quickly when in Final Cut (the project is also set to 48khz.) What’s even more strange is I stretched out the audio signal to a mark at the end of the set, but then audio in the middle was off (the audio mark at the beginning was still fine.) Does anybody have any ideas?
    Jim Rage replied 7 years, 11 months ago 1 Member · 1 Reply
  • Jim Rage
    October 24, 2018 at 6:36 pm
    I just figured out what’s going on. The Zoom H6 audio files have a few gaps throughout the recording. By “gaps” I mean the file looks fine, but when you listen to it long enough you’ll hear a sudden jump to later in the performance. I assume the card I was using wasn’t beefy enough for the stereo capsule, two line ins, and a -12db backup file. I’ll use my 32gb Sandisk Extreme Pro card from now on.
    I’ll try to do a test with the new card soon to see if it works. I’ll post the results.
