Activity › Forums › RE:Vision Effects › twixtor with final cut pro 6 – at 2K
  • twixtor with final cut pro 6 – at 2K
    Posted by Charles on July 8, 2007 at 2:00 am
    I just upgraded my final cut studio to version 2.
    Currently I am working on a 2K project, and have twixtor pro installed into it.
    However, I am having problems using the ‘noise’ in final cut pro 6 at 2k, and final cut shows
    a message saying that it can’t render nosie at 2K. How should solve this problem?
    ………….0101010101…
    Pierre Jasmin replied 19 years, 2 months ago 2 Members · 1 Reply
  • Pierre Jasmin
    July 8, 2007 at 5:56 pm
    https://revisionfx.com/support/faqs/hostfaqs/sequences_longer/#Apple%20Final%20Cut%20Pro
    “NOTE: We now suggest that you extend the clip by simply appending multiple copies of the original clip along the timeline in the intermediate sequence. This will create a new and different frame at each point in time. Now apply the Plugin to this intermediate extended sequence inside of another sequence. (We no longer suggest that you use the built in Noise video generator of FCP to extend a sequence).”
    Turns out that they replaced these effects by FxPlugs plugins (the Motion thing). In doing so they not only created the problem you are having but as well it won’t create a unique frame at every frame anymore. Bug reported at Apple, useful when clients file bugs as well.
    Pierre
    RE:Vision Effects
