Activity Forums Adobe After Effects Twixtor vs Timewarp
  • Twixtor vs Timewarp
    Posted by Jim Bachalo on July 10, 2011 at 8:45 pm
    Hi
    This great footage was done using Twixtor.
    https://vimeo.com/13557939
    Couldn’t the exact same result have been achieved thru Timewarp since they both use the same underlying Pixelmotion technology?
    What advantages if any does Twixtor offer?
    Local is the new global
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Chris Wright replied 15 years, 1 month ago 4 Members · 3 Replies
  • Barend Onneweer
    July 10, 2011 at 9:28 pm
    Twixtor and Timewarp are not based on the same code.
    Timewarp is based on Kronos software licensed from The Foundry, and Twixtor is developed by Re:VisionFX.
    I usually get better results with Twixtor – but occasionally Timewarp does better. Twixtor Pro has elaborate tools to help the software solve complex shots but I have no experience with those.
    Barend
  • Walter Soyka
    July 11, 2011 at 2:36 pm
    [Barend Onneweer] “Twixtor Pro has elaborate tools to help the software solve complex shots but I have no experience with those.”
    True. With Twixtor Pro in AE, you can use mattes to separate foreground and background elements, as well as track points and splines to help guide the motion estimation. Twixtor Pro can also import motion vector passes from a 3D application to help re-time rendered CG footage.
    Walter Soyka
  • Chris Wright
    July 11, 2011 at 9:21 pm
    timewarp works with masks. maybe not as advanced, but it works on hard shots.
    https://technicolorsoftware.hostzi.com/
