Activity › Forums › Adobe After Effects › Twixtor slow down to footage and to separate alpha matte how?
  • Twixtor slow down to footage and to separate alpha matte how?
    Posted by Rafael on September 2, 2005 at 6:39 pm
    I am applying using Twixtor Pro 4.5 a 50% speed change to a 24fps footage. From that sequence I’ve create a filmstrip and exported to Photoshop to paint the exact matte I wanted. So back to After Effect, I am applying Twixtor to each layer. But the Matte layer is not morphing the same way as the footage one. Is there a way to say to my Twixtor applied to the matte that I want the plug-in to affect based on the the other layer? Theere is an option named ‘Alt Motion Source’ which sounds like using another source layer, but noting hapens… Any twixtor gurus out there?
    Pierre Jasmin replied 21 years ago 3 Members · 6 Replies
  • Pierre Jasmin
    September 3, 2005 at 4:56 am
    The Foreground layers Mattes is an option in Twixtor PRO (it will use it when retiming)
    To twixtor a matte by itself you can set the ALT motion source to the live action source assuming they are time-aligned. The ALT source is the one use to perform the tracking then.
    You can post the question on our forum here at creative cow.
    Pierre
    http://www.revisionfx.com
  • Barend Onneweer
    September 4, 2005 at 9:07 am
    I think your problem would be solved by applying the alpha to the clip, then precomposing and then applying Twixtor to the resulting comp.
    If I’m understanding you correctly.
    Bar3nd.
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
  • Rafael
    September 6, 2005 at 5:32 pm
    Hi Pierre,
    So I followed what you said. I have 3 layers:
    Layer 1 is a pre-comp of the footage
    Layer 2 is a rotoscoped of the layer 1
    Layer 3 is the footage
    I applied Twixtor 4.5 to the Layer 2 and 3 and set the ALT motion source to Layer 1.
    It works for Layer 2, but Layer 3 show that pinkish-red, nothing. It doesn’t make sense at all to me, if Layer 2 is working why not Laayer 3?
    I followed the tutorial, the ‘Alternative Input’ is not documented as well as other sections, no After Effect project. I really don’t get it. ;(
  • Pierre Jasmin
    September 6, 2005 at 6:58 pm
    Does your roto has an alpha channel?
    If you do the roto in AE, you have to make it in a different comp
    Comp1: RotoComp or if it’s footage use Set Channel to put roto matte into alpha
    Comp2: RGB source(turn off layer)
    RotoComp
    Apply Twixtor to RotoComp and set ALT source to RGB source
    Pierre
  • Rafael
    September 6, 2005 at 7:11 pm
    I don’t understand what you wrote! It’s confusing.
    My layers are:
    Layer 1: the original footage RGB, layer turned off
    Layer 2: filmstrip created in Photoshop, no alpha channel based on the footage
    Layer 3: the footage RGB
    So I set up the layer 2 & 3 ALT to the Layer 1 on which I want to be based.
    I also did a version where I created a pre-comp for each layer, so my layers are long enough for a speed of 50%.
  • Pierre Jasmin
    September 9, 2005 at 8:52 am
    You need to set your composition to be duration of the amount of frames you need. In AE an effect cannot increase the duration of a sequence so you have to pre-comp and set duration appropriately or you can also as per above set the top layer as a solid (make the solid after you changed the comp duration) and apply Twixtor on the solid where color source is layer 2 and ALT source is layer 3.
    I am not sure I understand what layer 2 looks like. Is it a black and white image of the matte? The scenario I am describing here is to retime a matte without the RGB. As Barend said maybe what you need is just “set channel” (ae included effect) the roto matte into the alpha of the color source. When you do such thing you need to make that into a separate comp as AE does not honor effects applied to a layer when you ask for frames from a layer (unless it’s subcomped).
    Again Twixtor Pro only supports embedded controls for multiple-layers (defined by mattes)
    Pierre
