Activity › Forums › Adobe Premiere Pro › Twixtor problems
  • Twixtor problems
    Posted by Connor Benton on September 24, 2012 at 7:29 am
    Hi guys, I’ve been looking through these forums among others and I still am having a problem using Twixtor in Premiere Pro CS6. Using video taken from a ContourHD 1080, shot at 1280×720, H264 – MPEG-4 Codec, 59.940082 frame rate, 1.0 pixel aspect ratio, I am struggling to render Twixtor effects. When rendering in the workspace or exporting, I get an orange screen which Revision (the makers of Twixtor) says is due to the sequence settings not matching the source video. However, I have tried several methods to match the sequence settings to the source video including letting Premiere Pro match it up (the Change sequence settings dialog box), and trying to match it up manually with settings as follows:
    Timebase: 59.94 frames/second
    1280 x 720 (16:9)
    Pixel Aspect Ratio: Square Pixels (1.0)
    Fields: No Fields (Progressive Scan)
    Display Format: 60fps Drop-Frame Timecode
    What can I do to fix this problem? Thanks for you help.
    Tom Daigon replied 13 years, 10 months ago 4 Members · 3 Replies
  • Jon Barrie
    September 25, 2012 at 1:40 am
    Select the clip in the project panel.
    Right click on it.
    Select “New Sequence from Clip”
    This will make the sequence from the clips properties.
    – JB
    Jon Barrie
    Adobe Video Solutions Consultant ANZ
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Gilbert Carrizales
    December 4, 2012 at 7:01 pm
    I fixed the orange screen problem, now the other problem I’m having is that once I render my video to a finished product, the clips that contain the Twixtor effect flash the “RE:VISION EFFECTS” logo with a thin red X over the video. It does this repeatedly throughout the clips that contain Twixtor. How do I get rid of this?
  • Tom Daigon
    December 4, 2012 at 7:06 pm
    It sounds like you have a water mark. Purchasing the product OR reentering your license code is the usual way to solve this problem.
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=DxPrG3WUyz8
    (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
