Activity › Forums › RE:Vision Effects › twixtor & premiere cs4
  • twixtor & premiere cs4
    Posted by Denis Rudenco on October 26, 2008 at 10:59 am
    If i put clip then cut them from the beginig and apply twixtor i see black video. If i apply twixtor to non cut clip i see video normaly. Whats worng ?
    Pierre Jasmin replied 17 years, 10 months ago 2 Members · 11 Replies
  • 11 Replies
  • Pierre Jasmin
    October 26, 2008 at 5:17 pm
    Assuming you have the latest version:
    1) I just tried it in CS3 and not able to recreate
    2) Is this something you see in CS3 as well?
    Either way maybe send us a premiere project at techsupport@revisionfx.com
    Pierre
  • Denis Rudenco
    October 26, 2008 at 5:30 pm
    In cs3 all work fine! Only in premiere cs4 if i cut the clip and apply twixtor i see black video.
    I have windows 32 bit and x64 and premiere cs4 installed. On both system i see the same problem.
  • Pierre Jasmin
    October 26, 2008 at 9:51 pm
    Crap!… Quick test and looks worst then what you describe actually, as in “new last second bug in Premiere CS4″… let me see what I can do this week (if I can actually lie to Premiere so it returns the proper values). That said, do you see this with Quicktime movies, AVI or what (with fields, no fields) – so I can test all cases…
    Pierre
  • Denis Rudenco
    October 26, 2008 at 10:08 pm
    Sorry for my English. I can grab video from screen how i do this.
    Video file micrisoft DV lower fields 16:9
  • Denis Rudenco
    October 27, 2008 at 12:10 pm
    Here video of the bug
    http://www.immvideo.com/tcs4.wmv
    4 mb
  • Pierre Jasmin
    October 30, 2008 at 5:27 pm
    For those who keeps the score:
    I reported the following bug to Premiere 4.0.0
    “If you trim the begining of a clip in your edit timeline, then Premiere CS4.0.0 returns the wrong current time value to plug-in. There are workarounds, for Twixtor since often you need anyway to create a new sequence if you want to make the sequence longer, you simply need for now to make the in-point edit inside the nested sequence. Hopefully it will be fixed in 4.0.1 dot release”
    Pierre
  • Denis Rudenco
    October 31, 2008 at 7:33 am
    Thanks! Will waiting!
  • Denis Rudenco
    November 20, 2008 at 9:00 pm
    Crab!!!! After install premiere cs4 update 4.0.1 bug still not solve !!!! what the ….??
  • Pierre Jasmin
    November 20, 2008 at 9:14 pm
    Sorry about that, I did report it
    Feel free to report that in point trims cause plugin to use the wrong frames in CS4, worked fine in CS3
    Pierre
  • Denis Rudenco
    November 21, 2008 at 3:42 pm
    Adobe answer
    “I’d take it up with RE:Vision Effects” – Crab!! I hate always make “neast” sequence!!! So, what to do ?
