Activity › Forums › Apple Final Cut Pro Legacy › twixtor plugin failed to render
Posted by Core Van der hoeven on October 31, 2008 at 2:04 pmgetting nuts
every time I get the message; twixtor plugin failed to render when I try to render it
I’m working in AJA io HD prores 422 just 1 layerCan anyone help me
thanks,
CoreCore Van der hoeven replied 17 years, 10 months ago 2 Members · 4 Replies -
Rafael Amador
October 31, 2008 at 3:48 pmHi Core,
What size is your sequence, which Twixtor version are you using and which machine?
rafael -
Core Van der hoeven
November 1, 2008 at 4:13 pmWell as far as I know it’s the last version of twixtor
It’s a sequence of 5 minutes with 4 layers in and out fading text files, I didn’t use any other effect
I’m working on a mac pro 3.2GHz 8 core in total, with 12GB RAM and the NVIDIA Quadro FX 5600 graphic card
media is stored on the LAcie Biggest S2S with eSATAThanks,
Core -
Rafael Amador
November 1, 2008 at 4:47 pmHi Core,
I thought you may had not enough GPU, but with your system you shouldn’t have any problem.
rafael -
Core Van der hoeven
November 1, 2008 at 8:46 pmYeah it should be powerfull anough, even for this heavy plugin, maybe a fresh new install will help
Core
