Activity › Forums › RE:Vision Effects › Twixtor on Sony Vegas Pro – interpolation between multiple still images
  • Twixtor on Sony Vegas Pro – interpolation between multiple still images
    Posted by Walt Borders on March 4, 2015 at 8:59 pm
    I’ve been loading a set of multiple still images into Vegas Pro 13 and then trying to use Twixtor to create a new still image between each source image. The stills are from multiple cameras all pointing at the same scene. Think of a stereo camera but with 10 lens.
    My goal is to use still images to create in-between images that will be used to make auto-stereoscopic 3D lenticular prints.
    With Twixtor I’ve been getting plenty(!) of output JPGs, but none that have created an actual interpolated new image. Can I keep working with still images or do I need to create a 10 frame movie and work from that?
    Your direction and concepts are much appreciated! Thanks!
    Walt Borders replied 11 years, 6 months ago 3 Members · 4 Replies
  • Peter Litwinowicz
    March 5, 2015 at 1:02 am
    You do indeed need to make a 10 frame movie and work from that. (even if that’s to tell Vegas to load the 10 frames AS A MOVIE).
    Pete
    RE:Vision Effects, Inc.
  • Pierre Jasmin
    March 5, 2015 at 2:01 am
    A good way to do this in Vegas and to sequence your still frames on the timeline
    Then save that as a .veg file (project)
    And then load the .veg file as if you were loading a movie, within a new project
    And from there, follow Twixtor as usual instructions
    Pierre
  • Walt Borders
    March 5, 2015 at 3:24 pm
    Thanks for the info! I was going off in different directions and didn’t know what to focus on!
    Walt
  • Walt Borders
    March 5, 2015 at 3:25 pm
    The next step! Thanks for your help!
    Walt
