Activity › Forums › RE:Vision Effects › Twixtor breaking collapse transformations?
  • Twixtor breaking collapse transformations?
    Posted by Jimmy Brunger on November 11, 2014 at 3:41 pm
    Hi all,
    I have a problem whereby I’m trying to slow down quite a complicated composite…I get too many artefacts when applying to the render/master comp, so I’ve broken down the shot into instances of the same comp with different layers solo’d – so I can twixtor each one separately without layers crossing over each other and causing the ‘jelly wobble’!
    Problem is – I have to set collapse transformations for each solo’d comp to retain blend modes, but as soon as I apply Twixtor it forces collapse off?
    Is there any way to fix this? I’m using Twixtor Pro 5.2. Rest of my specs are below…
    Adobe CC 2014
    MacPro 2013 8-core 3GHz / 64GB RAM / Dual FirePro D500s / OSX 10.10
    Decklink Extreme+ 3D / 2TB SSD RAID-0 scratch / XServe + UD RAID on Small Tree 10GbE
    Pierre Jasmin replied 11 years, 10 months ago 2 Members · 3 Replies
  • Pierre Jasmin
    November 11, 2014 at 5:54 pm
    I am not sure why Twixtor would turn off CT/CR
    You say solo, shouldn’t you select layer and menu Pre-compose?
    Pierre
  • Jimmy Brunger
    November 11, 2014 at 6:18 pm
    Hi Piere,
    Sorry maybe wasn’t clear…they have been precomped, but essentially i’ve got 5 precomps of the same thing, but each one has certain layers within that are visible. It is these layers i need to twixtor individually so no crossing over of objects. I am then stitching them back on top of each other in the parent comp where the instances of twixtor are being applied. I need them CR’d though so it looks through into each one to honour the blend modes.
    Thanks for any thoughts you might have.
    Adobe CC 2014
  • Pierre Jasmin
    November 11, 2014 at 6:24 pm
    It might be easier if you have a way to send to techsupport @ revisionfx dot com a project
    Pierre
