Activity Forums RE:Vision Effects Twixtor black line
  • Twixtor black line
    Posted by Joe Riggs on December 14, 2014 at 8:35 pm
    In Premiere CS6, 5k Red footage in a 2k Scope sequence.
    When a nest a clip and apply twixtor, the image compresses a bit, almost as if it is scaling down and I get a black line at the bottom.
    I think it has to do with nesting the clip in that sequence resolution as I don;t get the line when I apply it
    to unnested clips or nested clips at 5k resolution, any solution?
    Joe Riggs replied 11 years, 9 months ago 2 Members · 2 Replies
  • Pierre Jasmin
    December 15, 2014 at 1:43 am
    I am not sure why you get a black line (if you set to show source is the black line there?)
    You could do the Twixtor in AE and reimport in Premiere to maintain full bit depth. It will currently do that in Premiere.
    Pierre
  • Joe Riggs
    December 15, 2014 at 6:48 am
    ” I am not sure why you get a black line (if you set to show source is the black line there?)”
    Yes with “source” it is still there but when I take off twixtor, it’s not.
