Activity Forums RE:Vision Effects Twixtor and HDV
  • Twixtor and HDV
    Posted by Rob De jong on September 2, 2008 at 6:07 am
    Hello,
    Can Twixtor deal with HDV material. How are the results in comparison with SD.
    What are the system requirements for Twixtor dealing with HD?
    Rob
    Pierre Jasmin replied 18 years ago 2 Members · 1 Reply
  • Pierre Jasmin
    September 3, 2008 at 9:49 pm
    There is not much particular I can think of to HDV other then it will take more time to process then SD (more pixels) and it can be pretty noisy (eg a small pass of DE:Noise prior could help if you plan to as well play with colors. If your HDV is green screen you probably want to key out prior to retiming though.
    Pierre
