Activity Forums Adobe After Effects Twixtor AE Workflow Question
  • Twixtor AE Workflow Question
    Posted by Daniel Schmidt on April 28, 2011 at 3:56 pm
    I have some material shot in 50fps that I want to apply some time remapping to and then export as 25fps. I deliberately shot the material in 50fps to have these extra frames to work with when creating slow motion with Twixtor.
    When I import the 50fps footage into AE (interpreted at 50fps) and put it into a 25fps composition and then apply Twixtor, does Twixtor realize that it has 50fps to work with? Or can it only access 25fps because the footage (and Twixtor) rest in a 25fps composition?
    Would it be better to have AE interpret the 50fps footage as 25fps (thereby slowing it down) and then place it into a 25fps comp and speed it up again to get it (or parts of it) back to 100%?
    Daniel Schmidt replied 15 years, 4 months ago 2 Members · 4 Replies
  • Pierre Jasmin
    April 28, 2011 at 6:02 pm
    You can do that – interpret footage to 25 FPS, drop that into a 25 FPS comp… And in Twixtor you then put 25 FPS for input frame rate.
    However you don’t need to do that in AE, you can also Make New Comp from that footage (then 50 FPS, and at same time make that comp as long in Comp Duration as will be needed), then drop that comp in a 25 FPS comp, and in Twixtor set input fps to 50.
    Also check this:
    https://library.creativecow.net/freitag_lori/twixtor-frame-rate-conversion/1
    or
    https://help.revisionfx.com/album/18/#/tutorial-36
  • Daniel Schmidt
    April 29, 2011 at 8:48 pm
    Thank you very much for your answer. The only thing I don’t understand is, why I need to create two comps and drop on into the other. Is that required for the frame thing to work properly or is that just so that the duration can be adjusted (instead of activating Time Remap)?
  • Pierre Jasmin
    April 29, 2011 at 10:06 pm
    It’s one way in the end to make the layer duration longer.
    Another one would be to set a solid layer of the right spatial dimension and apply twixtor there and set the color and track source to be the proper layer (and turn that layer visibility off).
  • Daniel Schmidt
    April 30, 2011 at 1:22 pm
