Activity Forums RE:Vision Effects Twixtor 60fps rendered into 24 fsp sequence
  • Twixtor 60fps rendered into 24 fsp sequence
    Posted by Peter Jordan on January 20, 2012 at 12:36 pm
    Hi am currently using after effects cs5 with twixtor pro to slow down footage, i have shot sequences at 59.94 fps and have used the program to slow it down, looks fine in after effects although once i have rendered this and put it into my 24 fps sequence in premier pro cs5 it looks choppy. I have tried to interpret the footage to 24 fps but this has resulted in missing loads of frames and looking crap… I know im doing something wrong but not sure at what stage during this process… Thanks
    Pierre Jasmin replied 14 years, 8 months ago 2 Members · 1 Reply
  • Pierre Jasmin
    January 20, 2012 at 8:35 pm
    I am not quite sure of the exact problem, is this what you are doing:?
    Import 59.94 FPS footage (it’s progressive 60P, not 59.94i with fields)
    Create a comp from that at 59.94, set the duration to proper length
    Import that comp in main comp, set main comp to 24P
    apply twixtor there, set Input FPS to 59.94 inside Twixtor
    render in AE 24P
    import footage in Premiere 24P
    If it looks good out of AE, should be good when importing in Premiere
    Is this what you are doing?
    Pierre
