Activity Forums Adobe After Effects Twixtor 5 & Adobe CS5 conflict
  • Twixtor 5 & Adobe CS5 conflict
    Posted by Greg Mccarthy on May 22, 2010 at 1:13 am
    I have just upgraded to both Adobe CS5 (Master Suite) and Twixtor Pro V5. I have been having problems with Premiere Pro CS5 only playing for about 5-10 seconds then stopping. It worked fine out of the box but started acting up as soon as I installed Twixtor V5 (I had not even used it. Just installed it). I did not know what was causing this stop playback problem at first and uninstalled/reinstalled Prem Pro with no luck.
    The only thing that I could identify that I had done differently since Prem Pro stopped working properly was install Twixtor Pro V5 so I also uninstalled Twixtor and low and behold everything worked fine again. I left it for a few days but this morning have tried re-installing Twixtor V5 and immediately got the same stop playback problem. Have now uninstalled Twixtor again and everything works OK again.
    I have also noticed that when Twixtor is installed that Prem Pro takes about three times as long to open.
    I am running a Windows 7 pro 64 bit system with 12 GB RAM, 2 quad core 2.66 Ghz processors and a Nvidia Quadro FX 4800 Graphics Card.
    I have been using Twixtor since V3 and Adobe forever and never had this problem.
    Any help would be greatly appreciated.
    Pierre Jasmin replied 16 years, 2 months ago 3 Members · 8 Replies
  • 8 Replies
  • Pierre Jasmin
    May 22, 2010 at 1:28 am
    Move the Twixtor folder out of
    C:\Program Files\Adobe\Common\Plug-ins\CS5\MediaCore
    into some place outside of Adobe folder
    Move it back, restart
    Does it really take 3 times longer to start now (or it was a coincidence)?
    Try to move Twixtor here
    \Adobe\Adobe Premiere Pro CS5\Plug-ins\Common\AEFilters
    Any difference?
    We don’t have that issue, based on what you find out, we can follow up with Adobe to see what is going on
    Pierre
    RE:Vision Effects
  • Greg Mccarthy
    May 22, 2010 at 6:56 am
    Hi Pierre. Tried all that. Still getting the same problem.
    I uninstalled all the old versions of Twixtor as well- thought maybe they were causing a conflict but with no luck.
    Have now uninstalled Twixtor 5 and everything is working OK again.
    Even when I had Twixtor sitting outside the Adobe folder I was still having the problem – had to completly remove it from my system before playback worked OK.
    The video footage I am using is from two Canon DSLRs (Canon 5 D MkII and the 1D MkIV)in the 1080 25p mode (I am in Australia). Even when I render the footage I still get the playback problem and I am not even using Twixtor.
    I am not a novice and even had a very experienced Video IT guy have a look as well but we are befuddled! My software is a properly licenced upgrade from Twixtor 4.5 which is an upgrade from version 3.
  • Peter Litwinowicz
    May 22, 2010 at 6:16 pm
    What is the date on the installer you have? I realized that I did not have the correct Microsoft runtime libraries the first time I made the installers. The date should be May 14, 2010.
    If the date on your Twixtor installer is before that, please download the latest version and reinstall.
    ALso I see that you said you have Twixtor 4.5 key, then are you using the Twixtor 5 installer and just running in demo mode?
    Pete
  • Greg Mccarthy
    May 23, 2010 at 1:55 am
    The date of the installer or at least the download date is actually 14 May 2010. That is the day I purchased V5 upgrade and received the software. Not sure if the download date is what you are talking about or is there some other date I need to check on the installer.
    I have a licence key for version 5 to upgrade from V4.5 which was also an upgrade from V3 (my first purchase of Twixtor) so when I install Twixtor V5 and use the licence key that came with the upgrade it then asks me for the original licience which I need to use the V3 licence code as V4.5 was also an upgrade.
  • Pierre Jasmin
    May 24, 2010 at 5:56 pm
    email to sales at revisionfx dot com if you need us to consolidate your license so you don’t need to enter all your upgrade history
    Pierre
  • Pierre Jasmin
    May 24, 2010 at 6:08 pm
    If you still have that problem write to us and I will open a case at Adobe Premiere. We have not seem that problem.
    pierre
  • Greg Mccarthy
    June 4, 2010 at 11:38 am
    Have worked out that the problem appears not to be related to Twixtor
  • Pierre Jasmin
    June 4, 2010 at 5:25 pm
    Thanks for the update
    Pierre
