Activity › Forums › Adobe Premiere Pro › twixtor
  • Posted by Eric Grove on August 20, 2014 at 4:52 am
    I am having issues with twixtor on premier pro cs6. I get an orange screen whenever I render. I have taken advice from other people with this issue. they said to make a new sequence from my video source so it matches all the parameters. I have done this, and a few other methods, and I still can not get it to work. i can view the edited video while not rendered. but as soon as I render, it goes orange
    I am using pre-existing video at 1920×1080 running at 23.976 fps. but again, I created a new sequence from the source video, so it should be a perfect match right?
    Blake Farber replied 11 years, 7 months ago 2 Members · 1 Reply
  • Blake Farber
    March 2, 2015 at 1:35 am
    I just made the switch from FCP 7 to Premiere CC. The FCP way of doing twixtor was drag and drop the plugin on the shot and change the speed, easy and done. But when I try it change the speed it puts the clip on a complete different time code mark not the same as already edited. Is there anywhere to just change the speed not changing the timecode from the edited point. I saw some tutorials on youtube that you have to make a new sequence with each clip then nest it on another. Is that true? Dont get why, or am I wrong? Is there an easy way to use to just drop onto an already edited timeline/clip?
