Activity Forums Maxon Cinema 4D Twisting torus loop
  • Twisting torus loop
    Posted by Cynthia Larenas on November 3, 2017 at 1:48 am
    Hi Guys,
    I have this set up (see below) but what I’m trying to do is twist the torus so that it loops and twists in on itself. To explain it a bit better, the shape should look like an hexagon at all times but I want to animate the twist so that it is twisting perfectly and continuously when played on a loop. Any ideas on how to do this?
    Charles Baez replied 8 years, 10 months ago 2 Members · 1 Reply
  • Charles Baez
    November 27, 2017 at 2:17 am
    Did you try animating the end rotation by key framing it from zero (first frame) to 400 (end frame)?
