Activity › Forums › Maxon Cinema 4D › Twisting Ribbon
Twisting Ribbon
Posted by Chris Mathews on March 9, 2016 at 8:44 amDoes anyone have idea how the twisting logo at the end of this video is created. I tried with twist deformer, but no luck.
https://www.youtube.com/watch?v=VptSr56EDBkWalter Volbers replied 10 years, 5 months ago 2 Members · 4 Replies -
Walter Volbers
March 9, 2016 at 9:47 amHello,
depends how the logo-grid is in space!
create a grid: Orientation +Y change it to the desired form,
then atache a Twist deformer, do not Fit to parent!,rotate the Twist-
deformer in P to 90degrees, now you should see the twist-effect, change the twist-deformers size
as you need it if, you now move/translate the deformer in z the twist is travelling trough the
grid,
hope this was clear -
Walter Volbers
March 9, 2016 at 9:54 amHello,
grid,
Chris Mathews
March 9, 2016 at 1:20 pmYes I figured that out, but I am asking about the folded logo at the end, like a twisted paper page.
Walter Volbers
March 9, 2016 at 2:34 pmohh sorry,
if you have access to studio/character you can then bind the grid eg. with two nulls
see attached example https://f1.creativecow.net/9870/bend-with-bind?uploaded=file
or this will also work https://vimeo.com/17051922 🙂
good luck
WalterSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
