Activity Forums Maxon Cinema 4D Twist Deformer
  • Twist Deformer
    Posted by Chris Joyce on September 5, 2011 at 12:48 pm
    I think this should have a simple solution just can’t seem to figure it out. I am trying to twist a slim shard so it flips 180 degrees. I am using the twist deformer but that only seems to twist it one way and I need it unravel back on its self.
    If that doesn’t make sense try adding the twist deformer to your scene then animating the angle so the top square of the deformer cube spins around. I also need to animate the bottom square.
    There must be a simple solution but so far am stuck.
    Chris
    Chris Joyce replied 14 years, 12 months ago 1 Member · 1 Reply
  • Chris Joyce
    September 5, 2011 at 12:51 pm
    Well I have just figured it out by adding another twist deformer and rotating it 180 degrees. I have alot of animation and keyframing to do on this project so if anyone has a better way that would be great as this could take quite a while.
    Cheers
