Activity › Forums › Adobe After Effects › twinkling stars…?
twinkling stars…?
Posted by Yamir Bhatt on July 28, 2005 at 2:56 amI wanted to create a sky with twinkling stars of diffrent colour glows. any one knows a tutorial on that? i guess expression could be used.
Jim Tierney replied 21 years, 1 month ago 4 Members · 3 Replies -
Damian Dunne
July 28, 2005 at 6:26 amyeah i think creating an expression would be the way to go. Something like the DIGIEFFECTS BESERK: de starfield plugin would do the trick as well. All their plugins are pretty cool for kiche stuff like that.
D. -
Filip Vandueren
July 31, 2005 at 12:47 amSometimes I use a very high frequency noise, and use a levels filter to crush it so bad that only a few points survive.
Blur that or use TrapCodes starglow, and then slowly animate the noise.Doesn’t give you coloured stars though.
You might also do it the other way around:
start with some coloured stars (perhaps even one of the true starmaps you can download) and multiply a high contrast, low fequency noise over it, slowly animate that: it will ‘twinkle’ the existing stars by obscuring them.
screen/add/lighten some more stars over that don’t change, and add some starglow if you need more kitsch.https://maps.jpl.nasa.gov/stars.html
the Yale map in particular works well: it only shows the brightest stars.
Jim Tierney
July 31, 2005 at 1:32 amIf you have AE 6.5, you can use CC Particle World or CC Particle Systems II to easily do this.
Very cool plugins…
cheers,
Jim——————
Jim Tierney
Digital Anarchy
http://www.digitalanarchy.com
415-586-8434
