Activity › Forums › Adobe After Effects Expressions › twinkling stars…?
  • Damian Dunne
    July 28, 2005 at 6:26 am
    yeah i think creating an expression would be the way to go. Something like the DIGIEFFECTS BESERK: de starfield plugin would do the trick as well. All their plugins are pretty cool for kiche stuff like that.
    D.
  • Filip Vandueren
    July 31, 2005 at 12:47 am
    Sometimes I use a very high frequency noise, and use a levels filter to crush it so bad that only a few points survive.
    Blur that or use TrapCodes starglow, and then slowly animate the noise.
    Doesn’t give you coloured stars though.
    You might also do it the other way around:
    start with some coloured stars (perhaps even one of the true starmaps you can download) and multiply a high contrast, low fequency noise over it, slowly animate that: it will ‘twinkle’ the existing stars by obscuring them.
    screen/add/lighten some more stars over that don’t change, and add some starglow if you need more kitsch.
    https://maps.jpl.nasa.gov/stars.html
    the Yale map in particular works well: it only shows the brightest stars.
  • Jim Tierney
    July 31, 2005 at 1:32 am
    If you have AE 6.5, you can use CC Particle World or CC Particle Systems II to easily do this.
    Very cool plugins…
    cheers,
    Jim
    Jim Tierney
    Digital Anarchy
    http://www.digitalanarchy.com
    415-586-8434
