‘Tweening’ a single attribute.
I’ve autotracked an object but need to do some tweeks. The circular window needs to zoom as the person moves across the room, so I set keyframes and use the ‘Between’ button to ‘tween’ them. This works fine for the zoom but now the Pan, Tilt and Rotate have changed because when I set keyframes I got a keyframe on each attribute, and when I clicked ‘Between’ they all tweened and so lost their tracking data. Is there any way to alter just one of them?
Thanks.
