tweaks to get good mpeg2 renders?
Like it says above. Most of the footage was shot HD, some with a SD cam. I’m getting okay exports using default NTSC Widescreen (1.2121 pixel ratio) Main Concept settings but there’s still a hunk of motion noise.
I tried an uncompressed AVI export (just a portion of a file) and it does look way better, so I’m assuming it’s the mpeg2 compression adding the noise. Is there anything in the Advanced Video tab of the MainConcept export dialog I should tweak to minimize the motion noise?
