Activity Forums Compression Techniques Tweak for Avid MXF files – is there a more robust method?
  • Tweak for Avid MXF files – is there a more robust method?
    Posted by Michael Kammes on December 21, 2010 at 5:13 pm
    Hey Gang-
    I’ve recently been privy to a trick to play Avid MXF files using ffmpeg. Basically it involves forcing (-f switch) the codec (DNxHD). The OP-Atom MXF Avid uses doesn’t play without the -f switch, unfortunately. An associate wrote a basic batch file to do this a bit easier, and now we have a basic, rudimentary way to play Avid MXF files – which, previously, was only available within Avid or by paying for the ability.
    I was curious anyone else had down something similar, or perhaps can / has ported this over to work under OS X.
    I detail it here: https://michaelkammes.com/avid/play-avid-mxf-for-free/
    ~Michael
    .: michael kammes mpse
    .: senior applications editor . post workflow consultant
    .: audio specialist . act fcp . acsr
    .: michaelkammes.com
    Michael Kammes replied 15 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
