Activity Forums Compression Techniques tvc requirement
  • tvc requirement
    Posted by Dan Newton on April 3, 2012 at 10:33 am
    hi
    need some help
    I was asked by a client to convert a mov to the following format:
    MPEG TYPE: H.264 MAIN
    STREAM TYPE: TRANSPORT ( VIDEO )
    VIDEO MODE: PAL
    CONSTANT BIT RATE: 1900 KBPS
    FRAME RATE: 25 FPS
    RESOLUTION: 720 X 576
    SAMPLE RATE: 48 KHZ
    BITRATE: 224 KBPS
    STREAM TYPE: TRANSPORT AUDIO
    AUDIO TYPE: MPEG LAYER 2
    MODE: STEREO
    Please can someone help me I am quite confused on some of the settings on when I go on to compressor it keeps giving me something different can someone help me/ guide me step by step on what I need to do.
    Your help is appreciated.
    Many Thanks
    Jeff Greenberg replied 14 years, 5 months ago 2 Members · 3 Replies
  • Jeff Greenberg
    April 3, 2012 at 12:12 pm
    What version of compressor? Version 3.5 may not be able to do this. Version 4 can.
    [Dan Newton] “when I go on to compressor it keeps giving me something different”
    What do you mean by this?
    Best,
    Jeff I. Greenberg
    Editor/Author/Speaker/Consulting
    My NAB seminar schedule, contact info and more
  • Dan Newton
    April 3, 2012 at 12:19 pm
    Hi
    Thanks for getting back to me.
    Well I use compressor 3.0.5
    I keep getting mpeg 2 but not the settings I need.
    So if I did this on 4 how would I do it.
    Please help.
    Much appreciated
  • Jeff Greenberg
    April 3, 2012 at 2:48 pm
    TYPE MOV
    VIDEO MODE: PAL
    FRAME RATE: 25 FPS
    SAMPLE RATE: 48 KHZ
    BITRATE: 224 KBPS
    MODE: STEREO
    Ok, so you need to create a new QuickTime preset (type mov)
    On the encoder tab, there’s a settings button – pick the h.264 codec
    QuickTime is a transport stream
    Bit rate is 1900kbs
    Frame rate 25, res 720×576 (and make sure compressors geometry tab matches)
    …and I’m not sure you can Mpeg Layer 2 audio. Perhaps they mean AAC?
    Can they give you a previously encoded movie to their specification?
    Best,
    Jeff I. Greenberg
