Activity Forums Apple Final Cut Pro Legacy Tv-studios run by mac?
  • Tv-studios run by mac?
    Posted by Mike Johnson on May 15, 2007 at 12:39 am
    Are there any TV studios that are completely run by mac? (no pc’s – other gear welcome tho)
    Perhaps some nifty fcp/xsan solution with kona/decklink?
    I’m interested in workflow and ideas.
    Jason Porthouse replied 19 years, 4 months ago 7 Members · 14 Replies
  • 14 Replies
  • Devin Crane
    May 15, 2007 at 12:58 am
    I’m sure they run both but ABC and the NFL runs Xsan.
  • Shane Ross
    I hear that KCBS here in Los Angeles here is. At least that is what I got from the Apple Event at NAB.
    And I hear that part of the BBC in London is as well.
    Why?
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Mike Johnson
    May 15, 2007 at 1:14 am
    Well, I’m interested in a solution like that.
    The best way is learning from others success!
    Got any more info on their workflow/setup?
  • Shane Ross
    May 15, 2007 at 1:42 am
    [Mike Johnson] “Got any more info on their workflow/setup?”
    I’d check the Apple Pro site and see if they have anything.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Arnie Schlissel
    May 15, 2007 at 1:49 am
    I think Oxygen is all Mac.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Paul Nevison
    May 15, 2007 at 9:55 am
    Unit post here in London is all Mac/FCP
    http://www.unit.tv
    G5 DP 2.0 (Power PC)
    4.0G RAM
    OS 10.4.8
    QT 7.1.3
    FCP 5.1.2
    BMD Decklink Extreme 6.0
    PAL Land
  • Walter Biscardi
    May 15, 2007 at 10:22 am
    [Mike Johnson] “Well, I’m interested in a solution like that.
    If it’s a large multi-User SAN, then your best bet is to work with a local VAR / broadcast integration company as setting up a large system like that is not something you want to jump into without proper planning. Even seeing how someone else is all set up is only good for initial ideas. Once it gets beyond that there are a ton of factors to be considered, not the least of which is support, and generally only a local company that can come on site to see your situation going to work out much better than putting something together yourself.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Mike Johnson
    May 15, 2007 at 1:01 pm
    Perhaps I need to be abit more clear what I’m after.
    I would like to read a guide or perhaps article about some of these places.
    What gear do they use, workflow etc?
  • Walter Biscardi
    May 15, 2007 at 1:18 pm
    [Mike Johnson]
    What gear do they use, workflow etc?”
    Those would only be available from something like the Apple Pro Stories at Apple.com, the websites of the production facilities themselves, the websites of the company(s) that did the setup, or through a trade magazine website.
  • Jason Porthouse
    May 15, 2007 at 3:05 pm
    I believe Granada TV in Bristol (UK) run an all Mac setup, with a few terabytes of networked storage and edit suites/dubbing suites all sharing. I think they’ve even a few ‘floating’ portable edit stations for producers etc. to log, trim and the like. No playout or anything like that AFAIK, but a pretty big throughput nonetheless
    As Walter says, not something you want to do without reading the instructions first 😉
    Jason
