Activity › Forums › Adobe After Effects › TV Snow tutorial/tips
  • Simmizi
    May 2, 2006 at 8:28 pm
    maybe this will help you…
    https://www.ayatoweb.com/ae_tips_e/ae25_e.html
    i think fractal noise will be the best choice for this effect…just animate the evolution-setting
    simmizi
  • Marcusc
    May 2, 2006 at 8:47 pm
    Thanks for the tip…it worked.
    In case anyone else needs it, here’s the process to create a :06 clip of simulated TV noise
    1. Create Light Grey solid
    2. apply Fractal Noise fx
    3. Fractal type-Rocky
    4. Noise type-Block
    5. Inside Transform, Scale width is 10, height is 5
    6. Complexity set to 6.0
    7. Evolution is 0 at :00, at :06 it’s 100
  • Aharon Rabinowitz
    May 3, 2006 at 1:01 am
    try applying the noise effect to a solid, make sure it’s monchromatic, and then just scale it up to 400%+.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Michael Duff
    May 3, 2006 at 2:54 am
    digitise some in from tape then use transfer modes…..
    or search the archives, i’m sure you will find many similar posts
