Activity Forums Adobe After Effects TV snow animating to text? Can anybody help?
  • TV snow animating to text? Can anybody help?
    Posted by Jake Martin on July 12, 2007 at 3:16 pm
    Hi
    I want to animate text from TV snow so that I begin with a screen filled with tv snow and it gradually gets pulled together to form a word. Can anybody help? I have Trapcode particular if this is something that might be done using particles.
    Many thanks in advance
    Jake
    Jeff Mcbride replied 19 years, 1 month ago 2 Members · 1 Reply
  • Jeff Mcbride
    July 12, 2007 at 6:16 pm
    Try typing the word you want, then go to Layer–> Create Outlines. This creates a new layer that uses masks to replace your text (making it unsuitable for editing later) If you type M with the layer selected it will drop down all the mask properties.
    For TV static, apply Fractal Noise and set it up roughly like this:
    Noise Type: Block
    Transform–> Scale: 2
    Complexity: 1
    Then animate the evolution over time.
    To get the pull together text effect you could select all your masks, set a keyframe, move backwards on the timeline and double-click them in the comp window to get a bounding box, then scale them up holding Shift+Apple (or whatever the Windows equivalent to Apple is) If you need more distortion you can continue to skew the mask shapes and plays with some distortion effects.
    Hope that helps.
