TV Simulator Issues
Posted by Ali Jackson on December 26, 2019 at 2:05 amHello Guys,
I need help with a current issue I am experiencing within Sony Vegas Pro 17.0. I’ve uninstalled and reinstalled over a hundred times trying to fix the issue since I thought it was the app itself. I’ve even searched youtube videos to see if someone had the same issue as me and nothing appeared
I’ll post a picture if possible
Daniel Barraclough replied 6 years, 8 months ago 3 Members · 8 Replies -
Daniel Barraclough
December 26, 2019 at 9:40 am1. Go to %temp% in Windows and delete all entries where possible.
2. Hold down the CTRL + SHIFT keys at the same time AND ALSO AT THE SAME TIME double click Vegas program icon on Desktop to Boot program.
Window will pop up.
Select Delete all Cached Application Data and then press Yes.
This will restore program to Factory Default Settings.Daniel, UK
Ali Jackson
December 26, 2019 at 5:09 pmDoes this also include deleting the folders are only the temp files?
Daniel Barraclough
December 26, 2019 at 5:21 pmPlease delete all in Windows %temp% that is deletable.
Daniel -
Ali Jackson
December 26, 2019 at 5:38 pmI did and it still doesn’t show the full menu for tv simulator. 🙁
Daniel Barraclough
December 26, 2019 at 5:56 pmAre you using a PC monitor or a TV? A TV can truncate the viewing real estate.
Daniel -
Bob Moyer
December 27, 2019 at 6:46 pmHave you checked your screen resolution? Sometimes if it is greater than 100%, it will truncate some of the windows.
Daniel Barraclough
December 30, 2019 at 8:03 amUp to now then, there is nothing wrong with Vegas application or Windows. You have cleared the %temp% folder and factory reset the video editing application. You need to investigate elsewhere than the above.
Regards,
Daniel, UK
