Activity Forums VEGAS Pro TV simulation fx
  • TV simulation fx
    Posted by Carson Young on May 31, 2007 at 7:56 pm
    Hi everybody,
    What i’m tring to do is simulate a tv look. Ive used TV simulator event fx and added noise as well. It looks great thus far however im also trying to create the effect of the tv screen shutting off. Kind of like the older school tv’s that when you shut them off the go dark from outside to inside…I’m experimenting with a circular iris transition from out to in, but it’s not quite the look im going for. Any ideas??
    Thanx,
    Carson
    Carson Young replied 19 years, 3 months ago 2 Members · 4 Replies
  • Gary Kleiner
    May 31, 2007 at 8:24 pm
    I’d use track keyframes to narrow it down vertically, then squish it horizontally.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Carson Young
    May 31, 2007 at 8:32 pm
    Oh yeah, great idea! I’m assuming when you say track you mean track keyframes motion?? If so what would be the easiest way to do that? I havnt dabbled with track motion to much.
  • Gary Kleiner
    May 31, 2007 at 9:01 pm
    Yes, track motion.
    Set a keyframe for full screen size where you want the change to start. Set a keyframe with the vertical squish a second or so later. Set a keyframe with the horzontal squish a second or so after that.
    Season to taste.
    Also, at the end, I would add a separate event that is a blurry white circle in the center that fades out over a coule of seconds
    Gary Kleiner
  • Carson Young
    May 31, 2007 at 11:30 pm
    Awesome, thank you very much for the great ideas! i’ll try them out.
    Carson
