Activity Forums Adobe After Effects tv screen effect
  • tv screen effect
    Posted by Bender on March 5, 2006 at 1:00 pm
    hi … i trie to make a zoom into a tv screen … now i want to add some of these moire tv lines effect … and i want that to look pretty realistc…
    any suggestions?
    thanks so much!
    best
    florian
    Zander replied 20 years, 6 months ago 4 Members · 3 Replies
  • Jeff Blasczyk
    March 5, 2006 at 1:03 pm
    If you go through the tuitorals on this site, i’ve seen one that shows you how to do the lines.
    jeff
    thanx,
    jeff
  • Josh Miller
    March 6, 2006 at 1:44 am
    https://www.creativecow.net/articles/rabinowitz_aharon/old_tv/index.html
    Or your could even simply apply a venetian blinds effect for a quick solution
    Josh
    rainorsun.com
  • Zander
    March 7, 2006 at 1:34 am
    wow, this sowns like shamless promotion, but i discovered these plugins the other day, https://www.petewarden.com/ one of the FREE plugins has a tv pixles options,
    this should create what your looking for, more of a moderen tv aproach rather then aharons (fabulous) tv tutorial, which is worth it for the glair idea alone, but when zoomed in won’t looks like a real tv, perhaps a combinations of the two?
    then using either pet wardens fisheye, or sphereize, you can get teh matrix effect of surface tension throught eh tv as the camera “pushes” through into the matrix tv center.
    hope this helps
    -Zander
