Activity › Forums › Adobe After Effects › tv scramble fx
tv scramble fx
Posted by Paolo Mugnaini on March 21, 2007 at 12:57 amDoes anyone know how to make the channel scramble fx in AE?
thanks
PPaolo Mugnaini replied 19 years, 5 months ago 2 Members · 4 Replies -
Kevin Camp
March 21, 2007 at 3:27 pmif its a scrambled tv picture like you might see if you tried to watch a cable channel that you weren’t paying for… i think displacement map with fractal noise as the map layer, and a wiggle expression on the amount of displacement so it jumps around a bit might work. you may also need motion tile, so the image will wrap as it goes off one side of the screen.
Kevin Camp
Designer – KCPQ, KMYQ & KRCW -
Paolo Mugnaini
March 21, 2007 at 8:03 pmHey sorry,
yes when there’s an interference and scrambled tv channel.
thanks
P -
Kevin Camp
March 21, 2007 at 8:25 pmthere are actually a couple of bad tv signal animation presets in ae7 that you could look at and try to modify or pick apart. they are in the one of the image presets. try typing ‘tv’ in your effects and presets panel.
Kevin Camp
