Activity › Forums › Apple Final Cut Pro Legacy › TV Safe Question
TV Safe Question
Posted by Max Frank on August 3, 2006 at 11:12 pmHi,
I’ve just inherited a project that has hundreds of titles and text instances that are just JUST OUTSIDE of the title safe area [smaller box] – but well with the screen-safe area.
My question is, how much wiggle-room do I have?
Or does all the text definately have to be within the smaller box, or else!?!Thanks,
Wayne
2DP G5, 3.5GB RAM, FCP HD
Bouncing Account needs new email address replied 20 years, 1 month ago 5 Members · 5 Replies -
Dan Riley
August 3, 2006 at 11:18 pmThat’s totally your call and your client’s call.
There is no “title safe police” out there.
In my experience you can go way below the title safe box
and be fine. Just experiment with various TVs and monitors
to see what’s safe to you.If you watch CNN, that crawl at the bottom of the screen
is WAY out of title safe and yet most TVs are fine with it,
but some, like an older 13 inch Sony set I’ve got,
it can barely see that crawl. Of course, the new LCD TVs,
they see the entire raster. And remember that web video
you make as quicktimes, that box shows the entire raster as well.Dan
Aaron Neitz
August 3, 2006 at 11:39 pmYeah, safe areas are increasingly subject to suspicion. Better transmission standards, better quality televisions…. 9 times out of 10 I wouldn’t sweat titles slipping out of title safe a bit.
Max Frank
August 4, 2006 at 12:06 amThank you gents – that was most helpful.
Wayne
Tony
August 4, 2006 at 3:42 amJust understand if the one tv your paying client is watching happens to cut off the type and they jump and downing screaming about out it you will have no one to blame but yourself.
So to be completely safe use the safe title as your guidelines but fudging it a bit is acceptable as long as you are “safe” with any consequences.
Tony Salgado
August 4, 2006 at 12:05 pm[tony salgado] ”
Just understand if the one tv your paying client is watching happens to cut off the type…”Problem is, even with the so-called “SAFE AREA” followed, the clinets can always seem to FIND a creaky old tube-set SOMEWHERE (Aunt Bessie’s house?) that will still cut off the disclaimers.
(Hey, that’s not all BAD to the client, IS it?)
