  • Posted by Rap on February 28, 2007 at 6:08 pm
    hey guys
    what do I use in order to make a frame look as a TV monitor
    I have a shot that I need to give the felling as if it was shot from a TV monitor, how do I change the borders and what effects should I add
    I have same shot that I wasnt to split to two, one full size frame regular and the second part as if it is from TV
    how can I make the borders lk a bit rounded?
    thanks
    Rafael Amador replied 19 years, 7 months ago 5 Members · 4 Replies
  • Ernie Santella
    February 28, 2007 at 8:03 pm
    Do you have Photoshop or After Effect? You can build it easy with those programs. Do a search on the forum, I think there’s been threads on this subject. Try adding scan-lines, noise to the image and even a glare/reflection spot, all that helps the illusion.
    Another way to make it truly realistic is to play the clip on a monitor and re-shoot it with a camera. I do that all the time and it looks great. Plus, you can do moves, swishes or zoom into parts of the frame for effect.
    Ernie Santella
    Santella Film/Video Productions
    http://www.santellaproductions.com
  • Max Frank
    February 28, 2007 at 10:15 pm
    Here you go:
    https://www.digital-heaven.co.uk/fcplugins/dh_retrotv.php
    Wayne
    osx 10.4.8 G5 2.0DP, 3.5GB RAM, FCP 5.1.2
  • Gabriele De simone
    March 1, 2007 at 4:00 am
    If I understand your reqs correctly, our company sells a plug-in called “Old TV” which fits the bill. It does a few things:
    – adjustable rounded corners (essentially, a geometric distortion that simulates the bumpy screen)
    – color adjustment to simulate old cathode ray tubes
    – scanlines with adjustable thickness and opacity
    – optional interference with lots of controls
    – lastly (a nice touch IMHO) an optional reflection on the screen – you can even supply your own reflected graphic via an image well.
    https://www.noiseindustries.com/fxfactory/images/editingpack/256/hulahoop_old_tv.jpg
    For more info
    Hope this helps,
    Gabe
    Noise Industries, LLC
  • Rafael Amador
    March 2, 2007 at 9:07 am
    If you got SHAKE, there is a macro that make everything for you, even faking different kind of CRT tubes and deformations. Is call TV Screen and you can download it from fxShare.
    Cheers,
    Rafael
