Activity › Forums › Adobe After Effects › tv picture effect
tv picture effect
Posted by Dan Newton on July 31, 2009 at 10:18 amHey
Have a question I am doing an edit where I have someone watching a tv now
What I want to do is place a small video on that tv screen
I know it has something to do with tracking
But. I am not sure on how to do it
Could some explain to me how I would do something
Like this
Awaiting for your replyRegards
Todd Kopriva replied 17 years, 1 month ago 3 Members · 5 Replies -
Jeremy Fabiano
July 31, 2009 at 6:32 pmWell there’s a few ways depending on the complexity of the shot..
I’ve been out of AE for a year due to a lot of non-related factors, but I’ll try to help based on what I can remember..
First off, you’re going to need the ‘corner pin’ tool and make your video clip fit to the screen. I would precompose the layer and move all attributes.
you’ll need to do motion tracking on the tv if its part of video, if its a static image, don’t worry about it, just apply the corner pin and call it a day. Oh, you’re going to need x,y tracking + scale as well (will give you 4 points to track, set them to parts of the tv that are high contrast). The scaling option will hopefully help out if theres any forward/backwards movement of the original shot.
Once you got that stuff looking the way you want, if you havent already, (and if the tv is a tube type not lcd/plasma) put an adjustment layer on it, and change the color a bit to look like a real tv set.. (id use curves and tint/w colorize perhaps, you’ll have to play with it and see if you like it).
I really hope this helps or at least gets you on the right track. If it works out shoot me a sample of how it looks, I always like to see when my advice benefits someone and how they used it 🙂
Good luck!
Dan Newton
July 31, 2009 at 8:46 pmHey
Thanks for getting back to me but please forgive me
This is new to me…
Can you explain to me …
Do I put a 4 point tracker on the first video with the tv
What about the new one where I want to place on the tv how
Would I connect them
So sorry guys for this please help and explainThx and regards
Dan Newton
July 31, 2009 at 8:47 pmHey
This is new to me…
Jeremy Fabiano
July 31, 2009 at 9:30 pmI’ll do my best to explain, but I haven’t touched afterfx in a year and I won’t be getting my pc back for a few weeks so this is from memory 🙁
The way i would do it is to make a null object
then put the 4 point tracker on the footage that has your tv
set the to the null object (the thing at the end of the tracking process cant remember its name)play it make sure your null stays put
once it works, then take the precomp of your footage that you want on the tv (take the footage, precompose it, then put the cornerpin to the precomp as well as color adjustments) and parent the precomp to the null object.
Now when the null moves it should move your ‘tv shot’
I hope that makes sense :S
Todd Kopriva
August 1, 2009 at 6:13 amThere are some excellent step-by-step tutorials about this. You just have to know what to search for. The magic phrase is ‘screen replacement’.
Here is an After Effects Community Help search for ‘screen replacement’.
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
