Activity › Forums › Adobe After Effects › tv picture effect
tv picture effect
Posted by Dan Newton on July 31, 2009 at 10:18 amHey
Have a question I am doing an edit where I have someone watching a tv now
What I want to do is place a small video on that tv screen
I know it has something to do with tracking
But. I am not sure on how to do it
Could some explain to me how I would do something
Like this
Awaiting for your replyRegards
Todd Kopriva replied 17 years, 1 month ago 3 Members · 2 Replies -
Michael Szalapski
July 31, 2009 at 3:53 pmIs your camera moving in the shot? If not, a simple corner pin effect will enable you to place your tv’s content (which I assume you have in a precomp) on the screen. If you have things moving in front of the tv screen, such as an actor walking through, you’ll have to duplicate your footage layer and rotoscope the person out so they’re in front of the TV.
If your camera is moving then everything’s pretty much the same, except instead of applying the corner pin effect manually, it might be easier to use corner pin tracking. I haven’t had any experience with Mocha yet, but there are help files on Adobe’s site and tutorials aplenty (including some here on the COW). If you want to use AE’s built in tracker, there are tutorials out there, but Adobe’s own help files will work nicely too. Basically, switch to the motion tracking workspace, select your footage layer, and choose Track Motion. Then under the motion type choose Perspective Corner Pin. Place your tracking markers on the four corners and go!
There are other tricks you’ll need to do that are the same with every compositing job. Match the color, blur level, and lighting on the TV precomp to the footage. Add some sort of light reflection on the screen (how this looks depends on what your TV looks like). And all those other normal things.
If the TV is a CRT one, don’t forget about reflections on the screen of things in the room, perhaps duplicating your footage layer, masking out the tv screen and laying it over your tv precomp with some layer blending mode and lowered opacity would work.
Also, don’t forget about the bending of the screen, you may need to try bezier warp, or some other distort tool to match the curvature of the screen.– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Todd Kopriva
August 1, 2009 at 6:13 amThere are some excellent step-by-step tutorials about this. You just have to know what to search for. The magic phrase is ‘screen replacement’.
Here is an After Effects Community Help search for ‘screen replacement’.
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
