Activity › Forums › Apple Final Cut Pro Legacy › TV not showing in playback…
  • TV not showing in playback…
    Posted by Jugglingstore on March 19, 2007 at 9:28 pm
    Hello,
    I have a fairly standard FCP set up. Computer, camera, headphones and a television. The TV shows up when I’m capturing video from the camera into FCP. However it won’t show up on video playback once the video is edited or out of the capture window. I’ve tried to go into FCP settings but just can’t seem to get it to work. Any ideas?
    Thanks in advanced,
    Brian Sutherland
    Jugglingstore replied 19 years, 6 months ago 2 Members · 2 Replies
  • Shane Ross
    March 19, 2007 at 9:29 pm
    #8 External Monitor Viewing.
    Shane’s Stock Answer #8:
    A simple path is mac > firewire > camera or deck > rca cables > tv
    Then start up your camera and tv, then open fcp.
    Then go View > External video > all frames
    Video playback should be Apple firewire NTSC (If you are using an NTSC set)
    Audio playback should be Audio follows Video
    Techinially, this should send synched video to your TV
    If for some reason you can’t view your timeline on your external monitor, there are a few things to try:
    1) Make sure that the camera/deck is connected and powered on BEFORE you open FCP.
    2) In the Final Cut Pro menu select AUDIO/VIDEO Preferences and make sure your signal is being sent out thru Firewire DV.
    3) Go to the menu and select VIEW>EXTERNAL>ALL FRAMES.
    4) Click in the % box above the image and select FIT TO WINDOW.
    5) Go to VIEW->refresh A/V devices
    6) Make sure the Log & Capture window is closed
    If you want it to play in both the canvas and the external monitor you need to go to the FINAL CUT PRO menu and select AUDIO/VIDIO settings and make sure MIRROR ON DESKTOP is selected under the PLAYBACK OUTPUT section
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Jugglingstore
    March 19, 2007 at 9:44 pm
    Wow, perfect!
    Thanks for the help,
    Brian
