Activity › Forums › Adobe After Effects › TV Look(Bluish w/Zebra Lines)
  • TV Look(Bluish w/Zebra Lines)
    Posted by Geo Conti on February 4, 2010 at 1:09 am
    Hello,
    I’m trying to achieve this tv effect/retro look that is in the video link posted below for an major class project. This was the best example i could find for what i am trying to achieve(sorry for the music). It’s an 3 video mix which all have the same effect( TV Bluish Look With The Zebra Lines and Flickering) . Can this be created in AE or FCP and is this maybe like an plugin or filter.Please help if you can. Thank you guys much
    https://www.youtube.com/watch?v=qGRFenp-bWU
    Bill Kelly replied 16 years, 7 months ago 4 Members · 3 Replies
  • Michael Szalapski
    February 4, 2010 at 2:20 pm
    There have been tons of postings here on the COW and all over the web on various TV looks. Here’s a quick search that turns up a ton of stuff.
    Basically, in AE, a venetian blinds transition gets you your lines, a levels effect gets you a bluish color and a wiggle expression on the opacity gets you a flicker. There is a lot more you can go into and the search I posted should give you all the info you need.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Todd Kopriva
    February 4, 2010 at 3:20 pm
    I’ll call specific attention to one of the results of the search that Michael provided: “Animation preset list”. That list shows that there are three animation presets that have “Bad TV” in their names. These can get you started.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Bill Kelly
    February 5, 2010 at 8:02 am
    Sometimes I think the easiest way is the best. Bring the footage you are going to use to be on the TV into After Effects and Interpret Footage>>Separate Fields>>Off. This will only work if your footage is interlaced and not progressive. You’ll see all the interlacing lines. Just add a little blue using Curves, Levels, Tint, or whatever you like, and add a small glow.
