Activity › Forums › DVD Authoring › TV flicker on DVD after aparently doing everything right
  • TV flicker on DVD after aparently doing everything right
    Posted by Ryan Garcia on June 16, 2012 at 10:24 pm
    Good day.
    I recently finished a dvd project. I wanted it PAL widescreen, this is what I did:
    -started sony vegas project with the settings: DVD/PAL 16:9 with Vídeo: 720×576, 25,000 fps interlaced.
    -rendered the project with the MPEG 2 DVD ARCHITECT WIDESCREEN STREAM PAL (plus ac3 for sound)
    -opened DVD architect project, with template MPEG 2 DVD PAL WIDESCREEN (16:9) 720×576:50i
    when I went to burn it, as I expected it did not tell me to reencode anything.
    Thing is, when I watched it I still get constant flickering throughout the whole video.
    Any ideas on to why this happens? ive burned projects before and followed the steps AFAIK correctly and flickering has been minimal.
    Thank you very much.
    Bill Stephan replied 14 years, 3 months ago 3 Members · 4 Replies
  • Eric Pautsch
    June 16, 2012 at 10:32 pm
    Whats the field order of your source and is it matched in the encode?
  • Ryan Garcia
    June 17, 2012 at 1:18 am
    How do I see the field order of the source?
    I checked and apparently the video was rendered with the lower field first. Should it be upper field first or progressive scan?
    Thank you.
  • Eric Pautsch
    June 17, 2012 at 5:13 am
    Try upper and see if that works
  • Bill Stephan
    June 18, 2012 at 5:30 pm
    PAL is always upper field first.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
