Activity › Forums › Compression Techniques › tv does’nt support .MOV, any alternative render options?
  • tv does’nt support .MOV, any alternative render options?
    Posted by Hoff Man on April 2, 2013 at 11:32 am
    in his blog https://www.videocopilot.net/blog/2007/0 … -settings/
    andrew suggests to use the quicktime render option.
    i need to publish a short teaser for an office event but the samsung TV that would be playing the clip file does not support quicktime (.mov) format.
    the supported codecs are .mp4 , .mkv, .avi, .wmv9
    from these list, im not sure which format displays the same good quality as Quicktime – animation render option.
    this site shows the complete supported codecs of the TV
    https://www.samsung.com/uk/consumer/lear … b_faq.html
    would greatly appreciate your replies
    Jeff Greenberg replied 13 years, 6 months ago 3 Members · 2 Replies
  • Craig Seeman
    April 2, 2013 at 2:30 pm
    The extensions are containers, not codecs.
    H.264, for example, can be .mov, .mp4, .f4v just to name a few.
    wmv 9 is a codec within wmv which can contain other wmv variants such as wmv 8, wmv 7, etc.
    Unfortunately your links are bad. Please fix if you want to share.
  • Jeff Greenberg
    April 2, 2013 at 5:59 pm
    [hoff man] ” the supported codecs are .mp4 , .mkv, .avi, .wmv9″
    As Craig pointed out – those are architectures (buckets_ not codecs.
    Both of your links were truncated – I can’t look up what the TV can do.
    Likely it’ll do h.264 MP4 files. What are you using as a compression tool? If you’re using compressor 4, you can make this sort of file.
    Handbrake can probably do this for you as well (for free) – use the Apple TV setting.
    Hope that helps (until you get us the other information!)
    Best,
    Jeff I. Greenberg
    Author/Master Instructor/Speaker/Consulting
    My contact info and more
    New! Come see me speak @ NAB/Post Production World!
