Activity Forums Broadcasting TV cuts top and bottom off
  • TV cuts top and bottom off
    Posted by Irene Meijer on March 20, 2009 at 1:49 pm
    Hello,
    Im working on a project, but I’m having a problem. I’m making a DVD with lots of different commercials. Some of them are 16:9, some are 4:3. Some are letterboxed, some not, etc.
    Every clip should be all over the screen, so I dont want any black bars on top and bottom. Exept for the 4:3 video’s and the black bars on the sides.
    I cut off the black bars with Quicktime and then scale it up to 720 x 576.
    I put the clips on a dvd with DVD Studio Pro.
    When I play it on the Mac it looks good, but when I play it on TV, it cuts some of the top and bottom off. Am I doing something wrong? Or is its the TV or DVD player?
    Irene Meijer replied 17 years, 6 months ago 2 Members · 3 Replies
  • Irene Meijer
    March 20, 2009 at 2:52 pm
    I just tested it on an other TV with a different DVD player and there it looked good. So maybe it was just the TV? It is an CRT TV, could that be reason? Because the other one I tested it on, which gave a good image, is a flatscreen.
  • Junaid Ahmed
    March 21, 2009 at 7:57 am
    Dear Meijer,
    You are towards right direction playing on different hardware.
    Your problem is related to aspect ratio. There are TVs in the market that have sub-standard quality. The screens are not actually 4:3 or 16:9. Some go out of “safe area”. So if you ever want to check/test a video, do it on professional monitor only.
    As far as conversion is concerned, it decreases the quality of video.
    Regards
    Junaid
    Technical Coordinator
  • Irene Meijer
    March 21, 2009 at 11:07 am
    Well thanks for your nice reply pff.
    I indeed don’t mind the pillarboxing, but I DO mind letterboxing. I want to cut those off, not the bars on the sides. The clips I have already have black bars on them. So it looks like I already made a choice. No letterboxing. Pillarboxing is ok.
    I just wondered if I did something wrong, because on an old TV it cuts some of and not on a flatscreen.
