Activity Forums VEGAS Pro TV Commercials – encode setttings
  • TV Commercials – encode setttings
    Posted by Duane Weed on October 31, 2011 at 11:31 am
    For local tv and cable what format settings do you use?
    I am using vegas 10. my project is HD. Looking for what settings are others using.
    Looking forward to being educated today – thanks.
    dw
    DW Video & Multimedia, LLC
    “Using Today’s Media To Market Your Business”
    Kent Vanderberg replied 14 years, 3 months ago 6 Members · 7 Replies
  • 7 Replies
  • Mike Kujbida
    October 31, 2011 at 12:36 pm
    You need to ask each station what they require as specs will differ from one to another, even in the same market.
  • Duane Weed
    October 31, 2011 at 12:44 pm
    Let me rephrase my question. Mov files for broadcast what settings do people use. Most of the spots are 30’s with a 1 gig limit. I am wanting to know what others use. Trying to get the best file at the smallest size.
    Thank you
  • Steve Rhoden
    October 31, 2011 at 3:29 pm
    For me most times they simply request it as DV on MiniDV Tapes.
    or if its HD i give them as a Quicktime format and i prefer to
    use the Photojpeg codec, because it handles compression well for
    smaller file sizes, while at good quality and can be played back
    on the most basic computer systems and can be re-edited on any
    software they have in house.
    Steve Rhoden
    (Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
    https://filmex-creative-media.blogspot.com/
  • Jonathan Thomas
    October 31, 2011 at 5:41 pm
    HD Technical Specifications
    Acceptable formats for HD spots
    Disks
    CD or DVD (be sure to list the titles on the Disk)
    MPEG-2 files or QuickTime (.mov, H.264) files are the only files accepted
    Electronically
    FTP *
    DG Systems**
    In order to receive a username/password to access the HD side of our FTP site you first must send us an HD spot to test and make sure it can go through the system correctly. You can test this by calling Time Warner.
    • Once we have a successful test, a username and password will be given to you to use. Please allow up to 5 business days for the username and password.
    • * Site address is ftp://24.106.236.181/. Internet Explorer must be used to access the FTP site.
    • Place all HD spots into the HD folder in either the “720” or “1080” subfolders.
    • The filename should be in all UPPERCASE
    • The filename should end with “HD” (to designate HD).
    • The filename should consist of only letters or numbers.
    Example. ABCHARDWARE – CLEARANCE_SALE_2009HD
    • File name can’t include periods, slashes or the pound sign
    • Each file submitted must contain only one commercial.
    • All commercials must have 5 seconds of black from the end of the slate to the start of each spot and 5 seconds of black from the end of the spot.
    ** Must have a DG Systems account setup. The phone number to contact DG Systems is 1-800-324-5672. Our System Code box # is 76.
    Video Format
    Format Vertical Lines Scan Type Frame Rate
    720p (1280×720) 720 Progessive 29.97 Progressive
    1080i (1920×1080) 1080 Interlaced 29.97 Interlaced
    Sampling Rate: 48KHz Average Audio Level: 0 dBfs
    Aspect Ratio: 16:9 Video Bit Rate: 15Mbps or higher
    Audio must be two channel audio.
    CH1 Stereo Left
    CH2 Stereo Right
    Video levels must not exceed 100IRE, Chroma levels must not exceed 110 IRE and Black levels must not go below 7.5 IRE at any time.
    Disks should be sent to the following address: Time Warner Cable Media Sales
    Attn:MasterControl
    Here are general specs for TimeWarner Cable. But others like WOW or AT&T may differ.
  • Jonathan Thomas
    October 31, 2011 at 5:48 pm
    General File Specifications
    Maximum Setup Levels
    7.5 IRE (SD) and ITU-R BT.79 compliant (HD)
    Maximum Luminance Levels
    100 IRE (SD) and ITU-R BT.79 compliant (HD)
    Maximum Chroma Levels
    120 IRE (SD) and ITU-R BT.79 compliant (HD)
    Average Digital Audio Levels
    Between –16 dBFS and –20 dBFS with high peaks
    between -10 dBFS and -12 dBFS and a maximum
    of three peaks per second
    Recommended SD Settings
    Video
    MPEG-2 program stream
    18 Mbps
    4:2:2
    9 frame GOP
    29.97i frames/sec.
    4:3 aspect ratio
    720×480 (720×486 if captioned)
    Lower (bottom) field first
    Audio
    MPEG-1 Layer 2, 2 channels (L-R), 48 kHz, 20 bit, 384 Kbps
    Recommended HD Settings
    For HD spots that are ready for delivery, DG can accept H.264 files
    at its regional FTP sites. However, Apple ProRes is the preferred
    format for files requiring production services such as watermarking
    and tagging.
    H.264
    Video
    H.264 (.MOV)
    50 Mbps
    4:2:2
    GOP structure not defined
    29.97i frames/sec.
    Field dominance not applicable
    1920 x 1080 (16:9 aspect ratio)
    Audio
    LPCM Integer (big endian)
    2 channels (L-R), 48 kHz, 16 or 24 bit, OR
    8 channels, 48 kHz, 16 or 24 bit
    Ch. 1 – 2: L – R front
    Ch. 3: Center
    Ch. 4: LFE
    Ch. 5 – 6: L – R surround
    Ch. 7 – 8: Lt – Rt stereo
    Apple ProRes
    Video
    Apple ProRes 422 HQ (.MOV)
    Automatic bit rate
    4:2:2
    29.97i frames/sec.
    Top field first
    1920 x 1080 HD (16:9 aspect ratio
    Audio
    2 channels (L-R), 48.00 kHz, normal quality, 24 bit
    DG Layout Requirements
    One spot per file
    File structure
    Minimum 1 second of black / silence
    5 seconds of slate
    2 seconds of black / silence
    Content – up to 120 seconds
    Slate requirements
    Ad code (ISCI / Ad-ID)
    Spot title
    Spot length
    Closed captioning (if applicable)
    Do not include resolution (e.g. 1080i) in the slate information
    Naming conventions
    The filename must match the ISCI or Ad-ID,
    e.g., for ISCI/Ad-ID ABCD1234,
    the filename would be ABCD1234.MPG
    For HD spots, the filename must end with an H
    (e.g., ABCD1234H). When submitting HD and SD
    versions of the same spot, the filenames should match,
    e.g., ABCD1234.MPG & ABCD1234H.MOV
    The filename must contain only alphanumeric characters.
    The filename must be all upper-case.
    The filename (excluding the extension, e.g., .MPG)
    must not be less than 3 or more than 15 characters
    (including the H to designate HD content).
    Incorrectly named files can delay processing of your spots.
    Here is another setting from DG FastChannel.
  • Stephen Mann
    November 1, 2011 at 3:51 am
    Hi Duane – haven’t seen you around the forums in quite a while.
    Steve Mann
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Kent Vanderberg
    May 14, 2012 at 1:13 pm
    When shooting HD and framing for 16:9, must one always protect for TV to center-cut crop the sides of the frame on 4:3 TVs? Our intent was to use the entire width of the 16:9 image and then letterbox it for 4:3 distribution. But a broadcast engineer wandered onto the set and said the letterboxed version would appear both letterboxed and pillarboxed on 16:9 TVs. Our frame included text on a sign which cannot be cut off if center-cropping might occur.
    I have a 4:3 TV at home. How is it that I see letterboxed 16:9 national spots all the time? I cannot believe that those spots are being letterboxed and pillarboxed on 16:9 TVs; they’re filling the 16:9 frame.
    I would like to distribute the spots in full raster 16:9 for everyone that is viewing on 16:9 TVs, whether viewing the SD channels or HD channels. But I DON’T want those viewing 4:3 SD to have the image center-cropped. How do the national advertisers manage to have their spots letterboxed on my 4:3 TV while playing full screen 16:9 on newer Tvs? Please explain. Thank you.
    Kent
