Activity Forums Adobe After Effects Tv commercial urgent help!
  • Tv commercial urgent help!
    Posted by Jazzalen on September 10, 2005 at 4:13 pm
    Hi!
    I am from Europe.
    I would like to ask what preset i must select in Ae to do commercial for Tv.I know Pal is for Europe.Should i first work in square pixel and then output final composition in D1\Dv Pal?
    And also when importing jpg,pdf or any other image,should i use interpretate footage otpion and select some uperfield settings,so the images will look good on tv,without any distortions or lines when scaling?
    Please help me,if is there any other things to look out,just write it.
    I use pentium 4 2.4 ghz with Nvidia geforce 6600 gt card.
    Tnx a million!!!
    Bhoneck replied 21 years ago 2 Members · 1 Reply
  • Bhoneck
    September 11, 2005 at 9:43 pm
    NTSC is 720×486. This should be fine unless you are working in the 16×9 aspect ratio, then you should work in the 864×486 and then stretch in the render cue to 720×486 stretch. For fields we usually use lower fields in our shop, but this is totally dependent on what system you are laying off too. Hope that helps
    Ben
