Activity › Forums › Adobe After Effects › TV Black and White No Sginal Effect
  • Angie Taylor
    April 20, 2011 at 1:31 pm
    Hi there,
    there are a few dedicated third party plug-ins that will do this. Like Sapphire’s excellent TV Damage filter. There are also some presets for “Bad TV” style effects in your presets folder but they don’t really have the effect you’re after. However, you can create this “Snow” type of effect with Fractal Noise. You need to adjust the Scale value down to a value of 1, choose Max as the Fractal type and Block as noise type. Sub-scaling set to 100. then animate the Evolution setting to taste depending on duration. You can then add the Bad TV preset on top to give it a bit more authenticity.
    Hope this helps 🙂
    cheers,
    Angie
    Angie Taylor animation & illustration for television, film, web and devices
    https://www.angietaylor.co.uk
    Twitter: theangietaylor
    Linkedin: theangietaylor
    https://www.facebook.com/pages/Angie-Taylor/118378194869002
  • Michael Szalapski
    April 20, 2011 at 4:11 pm
    I was just going to suggest the basic noise effect. But Angie, as usual, has a much more in-depth and better idea.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Shaher Yamisha
    April 20, 2011 at 6:12 pm
    thanks alot Angie 🙂 I tried it now ,it worked but I had no time back then
    so i search the web and i was luck to find some freebie 1080p Static Tv Stock Videos it was more realistic
    ^__^
    thanks alot
