Activity Forums Zaxwerks tutorial trouble too
  • tutorial trouble too
    Posted by Raystar Devo on April 9, 2006 at 3:57 pm
    Am having difficulty with Serge Hamad’s Layer Mapping tutorial and I’m sure it’s something basic that I am missing. I have created the ‘body’ and ‘visor’ objects from the .ai circle file and was able to map them with the body/transparency and divider maps respectively and everything works perfectly up to this point.
    Once I go to import a 3rd circle, name it (reciever), ID it as set3 and position it slightly above the body/visor sets, then when I go to view in afx comp window the body is gone? Bak to Invigorator and lo and behold it is gone in the Invig Set-Up window as well (not really gone, just mysteriously relocated) but visor is still in place.
    This is repeatable when project is built from scratch, or deconstructed and reassembled from the tutorial file. Invig is 4.0.6 pro, afx is 6.5 mac 10.3.9, user well above beginner evidently nowhere near expert.
    any help is good help
    Raystar Devo replied 20 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
