Activity › Forums › Adobe After Effects › Tutorial to create Bokeh Effect
Posted by Andrea Stewart on August 15, 2011 at 9:01 pmDoes anyone know where I might find a tutorial on creating a bokeh effect in AE? Its that look of floating balls or shapes of light that happens when a lens goes out of focus.
I have particular, and I figure that’s a good place to start.
Andrea Stewart
Producer/Editor/Director – Owner
Germane Creative LLCTodd Kopriva replied 15 years ago 3 Members · 4 Replies -
Walter Soyka
August 15, 2011 at 9:16 pmBokeh — the blur and bloom in out-of-focus areas of a picture — is a lens artifact. You can use the Camera Lens Blur effect in AE CS5.5 [link] to get a nice bokeh effect from existing footage.
Previous versions of AE use the older Lens Blur effect [link], but Camera Lens Blur is a big improvement over this.
Particular could certainly give you the blurred, overlapping shapes you’re looking for, but I don’t think it will be easy to get the same organic feel as you’d get from a real lens or good lens simulation effect.
You can also find many stock video clips of defocused lights.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Andrea Stewart
August 15, 2011 at 9:26 pmThanks Walter.
I’d like to have the look of the stock footage, but with more control. Mostly, I want to add an obscuration layer (specifically a photo) in 3D so the lights can pass over and around it.
Andrea Stewart
Germane Creative LLC -
Walter Soyka
August 15, 2011 at 9:43 pmMakes sense — in that case, I’d consider using Particular to create the shapes, then Camera Lens Blur to beautifully defocus them.
To get more of a depth-of-field effect, you could duplicate the particle system a few times and use the near and far vanish properties to slice it up, then apply Camera Lens Blur in varying amounts.
Alternately, you could create a couple dozen shape layers, position them in 3D space, and let AE CS5.5’s improved DoF rendering create the bokeh for you.
Walter Soyka
Todd Kopriva
August 15, 2011 at 10:55 pmHere’s some more information about the features in After Effects CS5.5 that Walter mentioned for this kind of work:
“Camera Lens Blur effect and camera depth of field properties in After Effects CS5.5”———————————————————————————————————
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
