Activity Forums Adobe After Effects Tutorial for deinterlace HD footage? Andrew Kramer?
  • Tutorial for deinterlace HD footage? Andrew Kramer?
    Posted by David Del on November 9, 2007 at 1:55 am
    I watched Andrew’s tutorial on deinterlacing DV footage with his scanlines PSD, but I have HD footage and the scanlines does not fit the screen because it is too small, is there a PSD for HD footage?
    Kevin Camp replied 18 years, 9 months ago 3 Members · 4 Replies
  • David Del
    November 9, 2007 at 1:59 am
    Nevermind, found them in the other folder. Thanks
  • Sam Moulton
    November 9, 2007 at 2:26 am
    I never thought much of that technique. ae separates fields internally by blending both fields into a full frame. Andrew’s technique throws away completely one set of fields and replaces it with a blurred version of the footage. I think that AE’s build in feature gives better results, especially with HD footage, but that’s just my opinion.
  • David Del
    November 9, 2007 at 2:44 am
    Thanks, it is just for motion tracking at this point, I am not going to use the Deinterlaced footage after that…
  • Kevin Camp
    November 9, 2007 at 4:58 pm
    for motion tracking you might also try ae’s separate fields, but put the footage into a comp that is double the frame rate (if the footage is 29.97, make the comp 59.94).
    then you’ll have data from every field to use for tracking.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
